disable ip-security arp validation
disable ip-security arp validation [dynamic | {vlan} vlan_name] [all | ports]
Description
Disables ARP validation for the specified VLAN and member ports.
Syntax Description
vlan_name Specifies the name of the VLAN to which this rule applies.
dynamic Configuration options for dynamically created VLANs.
all Specifies all ports.
ports Specifies one or more ports.
Default
By default, ARP validation is disabled.
Usage Guidelines
Use this command to disable ARP validation.
To display information about ARP validation, use the following command:
show ip-security arp validation {vlan} vlan_name
The following command disables ARP validation on port 1:1 of the VLAN valid:
disable ip-security arp validation vlan valid ports 1:1
This command was first available in ExtremeXOS 11.6.
Dynamic VLAN option added in ExtremeXOS 30.2.
Platform Availability
